Activity Forums Apple Final Cut Pro Legacy motion panel alignment problem in FCP
  • motion panel alignment problem in FCP
    Posted by Sachin Desai on March 27, 2010 at 4:08 am
    Hi!
    I’m working on final cut pro 6. its all working fine except the motion tab for a clip.
    the values for scale centre and rotate goes out of the sight. every time i have to re adjust the window to re arrange it. any idea how to slove this permanently.
    please check the image
    Sachin Desai replied 16 years, 6 months ago 3 Members · 5 Replies
  • Steve Eisen
    March 27, 2010 at 4:10 am
    “U” “Control” your window layouts. Press Control-U.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Arnie Schlissel
    March 27, 2010 at 4:11 am
    Select that window, then hold down the command key and press the minus key until the controls are the size you want.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Sachin Desai
    March 27, 2010 at 4:26 am
    i know this shortcuts but my question is how to set it default to show everything. its like every time I select clip for what ever reason may be filter settings or may audio setting this happens with all the tabs for each clip. I’ll have to sometimes ctrl+U doesn’t work either.
    any solution.
    thanks
  • Steve Eisen
    March 27, 2010 at 4:30 pm
    I would trash your preferences. I tried every combination to make my viewer window look like yours. I couldn’t do it.
    You could try moving your Parameters tab to the right.
    Steve Eisen
    Vice President
  • Sachin Desai
    March 28, 2010 at 12:13 pm
    well i’ll try that let me tell you one thing if I use 2 up layout it shows everything well
    its only where i use default layout..
    how to trash prefs
    thanks
    sachin
