Activity Forums Apple Motion Motion layer cropping
  • Motion layer cropping
    Posted by Chris Barber on June 28, 2006 at 3:33 pm
    hey guys,
    I’m importing photoshop files into motion and applying a drop shadow. the shadow is getting cropped at the edge of the layer. I know how to extend the layer cropping in combustion to correct this. however I’m not having any luck in Motion.
    Any help on this would be greatly appreciated,
    Chris
    Chris Barber replied 20 years, 3 months ago 3 Members · 4 Replies
  • Pwbeninate
    June 28, 2006 at 5:42 pm
    In the inspector, you can modify the size of the layer.
  • Doyle Rockwell
    June 28, 2006 at 6:08 pm
    Heya,
    Just to clarify: you’ll need to nest your PSD image in a layer and then (with the layer selected) go to the ‘Layer’ tab of the Inspector and enable Fixed Resolution. This stops the layer from shrinking-to-fit and lets you specify a hard size. You can then extend the layer to avoid the cropping of you drop shadow.
    Good luck with your project!
  • Doyle Rockwell
    June 28, 2006 at 6:10 pm
    Heya,
  • Chris Barber
    June 28, 2006 at 8:03 pm
    Ah-ha, the vital step. thanks for your reply
    Chris
