Activity › Forums › Adobe After Effects › Motion Graphic Template – Responsive Design Time / Protected Region bug in Premiere Pro
  • Motion Graphic Template – Responsive Design Time / Protected Region bug in Premiere Pro
    Posted by Alexis Fradier on February 3, 2020 at 12:43 pm
    Hello everyone!
    I’m working on a Motion Graphic Template kit in AE for an editor/client to use in Premiere.
    Everything is working great except I have a pretty annoying bug regarding the Responsive Design Time feature once the Mogrt are imported in Premiere.
    The RDT feature works well inside of AE when I put my template in another comp to test it : I have the blue protected region, and when I’m resizing/retiming the comp, the protected region keep their duration.
    But when I import them in Premiere with the Essential Graphics panel, the protected regions are slowed down or accelerated, and the outro animation happens at a random point in time.
    I’ve tested with a simpler comp (just a text with little animation) and it works.. That means, maybe it is something in my animations that break the RDT ? (That’s the scary hypothesis)
    Would you have any ideas what can break the RDT features only in Premiere ? I have no sounds in my templates, no time-remap, nothing I can think of that can impact the time remapping process.
    My mogrt are 1920×1920 comps as they need to fit either a 1920×1080 comp, or a 1080×1080, or even a 1080×1920 (vertical) edit… And I may also add that everything is at 25fps.
    I’m working on MacOS 10.13.6
    With AE 17.0.2 (build 26)
    And Premiere Pro 14.0.1 (build 71)
    I would be glad to share one or two mogrt files if necessary.
    Anything that can point me in the right direction would be much appreciated.
    Thanks a lot !
    Eugene Constable replied 5 years, 2 months ago 2 Members · 1 Reply
  • Eugene Constable
    July 29, 2021 at 1:18 pm
    Hey Alexis – realise your post here is pretty old, but I think I have encountered exactly the same problem, Responsive Design Time not working in Premiere on some Mogrts (built in AE) as it should. Premiere is ignoring the ability to time-stretch the clip, even though the Intro and Outro regions usng RDT are applied in the AE comp.
    No audio in the Mogrts, or time remapping..but they do have a few expressions in there, but I can’t see how these would affect it.
    Just wandered if you ever found an answer, or if it’s a bug – I’m stumped!
