Activity Forums Apple Motion Motion Generator Limiting Duration
  • Motion Generator Limiting Duration
    Posted by Mark Andrews on July 8, 2014 at 2:46 am
    I am new to creating generators and transitions in Motion and using them in Final Cut X. I’m sorry if this is a basic question but I cant find the answer anywhere.
    I’ve created a generator and would like to limit the length of it. When it’s placed in Final Cut X, it comes in at 4 seconds. I would like to restrict the length to 4 seconds so it can’t be extended or shortened.
    Thanks for any advice,
    -mark
    Alex Gollner replied 12 years, 2 months ago 3 Members · 2 Replies
  • Robin S. kurz
    July 9, 2014 at 10:35 am
    Then you’ll need to use something other than a generator, since that’s their nature and the whole point behind them. They are resolution and time independent, no matter what. Unless there’s a setting/option that I’m not aware of.
  • Alex Gollner
    July 14, 2014 at 8:15 am
    You can’t do anything in Motion to stop an editor changing the duration of a generator in Final Cut. You can however make sure it only shows content for 4 seconds or less – however much the editor increases the duration of the generator in the timeline.
    Set up the Motion generator to be 4 seconds long and 1 frame.
    Create your content so its duration is 4 seconds long
    Deselect everything, go to the last empty frame
    Set a marker: Mark > Markers > Set Mark
    Choose Mark > Markers > Edit Marker
    Change the new marker’s Type to ‘Build In – Mandatory’
    Now when you use this generator in Final Cut, it won’t scale any of your work in time – all behaviours and animations and duration will be fixed to 4 seconds and then vanish – if you make sure no content is visible in that last frame.
    @Alex4D
    ___________________________________________________
    Alexandre Gollner,
    Editor, Zone 2-North West, London
    alex4d on twitter, facebook, .wordpress.com & .com
