Activity › Forums › Apple Motion › Motion exporting compression problem
  • Motion exporting compression problem
    Posted by Trish Hagen on October 16, 2009 at 8:01 pm
    I just finished a motion text animation project that I need to use FCP. I am using Motion 3 and when I exported it using animation compression it looks all pixilated and not the look I want. Any one know what compression would be best? thanks
    Zak Peric replied 16 years, 11 months ago 3 Members · 2 Replies
  • Stephen Smith
    October 16, 2009 at 9:12 pm
    I export out movies using the Animation codac all the time. This TV Show Open used the Animation setting. I’ve found that if text looks bad, make sure you export out your video set to Best instead of Normal. Go to File, Export. Options. Click on the Output tab and un-check the “use current project and canvas settings” check box. Set Render Quality to Best. Hope this helps.
    Utah Video Productions
    Check out the Graphics Demo Reel I did.
    Check out my Motion Tutorials
  • Zak Peric
    October 17, 2009 at 7:43 am
    I would agree with Stephen.
