Activity › Forums › Avid Media Composer › motion effects error
  • motion effects error
    Posted by Brian Musser on February 24, 2006 at 9:18 pm
    Weird problem – looking for some insight…
    I’m taking an offline done at DV25 and decomposing it so I can online at 1:1. After decomposing I unlink the DV25 rendered effects that for some reason still link to the decomposed sequence. Then I set my render settings to render motion effects at INTERPOLATED and other effects at HIGHEST QUALITY. When I try to render the sequence any motion effects that were not originally set to INTERPOLATED during the offline will not render. I get an error message saying “An ACCESS_VIOLATION exception occurred”. The only solution I’ve found is to manually recreate all of the motion effects. Is there a better solution?
    Any help would be greatly appreciated.
    -Brian
    Brian Musser replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
