Activity Forums Avid Media Composer Motion effect?
  • Motion effect?
    Posted by Bryant on May 27, 2005 at 5:24 am
    I figured this would be easy, but it turns out i cant figure it out for some reason. So, How do you get the audio to slow down with a motion effect?
    Carl Amoscato replied 21 years, 3 months ago 3 Members · 2 Replies
  • Michael Thomson
    May 27, 2005 at 8:46 am
    Options as far as i know are:
    export audio to external editor to apply an effect then re-import it
    use an audiosuite plugin, think its pitch or something, sorry can’t remember the name off hand
    or the other option is that you redigitise the sections audio again but by slowing it down with the jog/shuttle wheel as you digitise
    Hope theres a solution there for you
  • Carl Amoscato
    May 27, 2005 at 2:40 pm
    Audiosuite time compression/expansion plugin on your audio clip.
    good luck,
    Carl
