Activity Forums Apple Motion Motion Crashing in active camera view
  • Motion Crashing in active camera view
    Posted by Matt Doe on September 11, 2007 at 3:49 am
    A little background.
    Updated to Motion 3.0.1 before beginning the project and repaired disk permissions.
    I am working on the opening to a travel video for a friend. I imported 2 DV clips of about 50 seconds each into motion and applied effects to give it that reflection off the floor look similar to the coverflow view. I am at the point where I want to animate a camera movement between the two clips, mainly along the Z axis having the second clip placed “behind” the first.
    I was working in perspective view, had no problems there. I then switched into active camera view to work out the camera move…Motion crashed.
    Now when I go to open the project back up, Motion crashes before fully opening the project. I can see from the brief time the project is open that it is set to active camera view.
    Any ideas as to what may be causing the problem, or have you run into the same sort of thing?
    Matt Doe replied 19 years ago 1 Member · 0 Replies
  • 0 Replies
