Activity Forums Apple Motion Motion Crashes
  • Motion Crashes
    Posted by Leng Ong on April 6, 2011 at 1:43 am
    This is clearly a common problem, however it seems there could be many causes. I am a newbie to macs and motion. Could someone help me in deciphering the reason why motion crashes on me at startup. I can post the log…its all greek to me! Any help would be appreciated.
    Thread 0: Dispatch queue: com.apple.main-thread
    0 libSystem.B.dylib 0x92e140fa mach_msg_trap + 10
    1 libSystem.B.dylib 0x92e14867 mach_msg + 68
    2 com.apple.CoreGraphics 0x9138906e _CGSSetTrackingAreaOption + 151
    3 com.apple.CoreGraphics 0x91388fcc CGSSetTrackingAreaOption + 393
    4 com.apple.AppKit 0x98a4932a _setTrackingRect + 429
    5 com.apple.AppKit 0x98a49168 -[NSWindow _setTrackingRect:inside:owner:userData:useTrackingNum:install:] + 617
    6 com.apple.AppKit 0x98a48ef6 -[NSWindow _setTrackingRect:inside:owner:userData:useTrackingNum:] + 99
    7 com.apple.AppKit 0x98a48cc9 -[NSView(NSInternal) _installTrackingArea:] + 384
    8 com.apple.AppKit 0x989aa7a9 -[NSView(NSInternal) _installTrackingAreas:] + 162
    9 com.apple.AppKit 0x989a9e8c -[NSView _setWindow:] + 2085
    10 com.apple.AppKit 0x989f94e9 __NSViewRecursionHelper + 40
    11 com.apple.CoreFoundation 0x9394b2c0 CFArrayApplyFunction + 224
    12 com.apple.AppKit 0x989a9df5 -[NSView _setWindow:] + 1934
    13 com.apple.AppKit 0x989f94e9 __NSViewRecursionHelper + 40
    14 com.apple.CoreFoundation 0x9394b2c0 CFArrayApplyFunction + 224
    15 com.apple.AppKit 0x989a9df5 -[NSView _setWindow:] + 1934
    16 com.apple.AppKit 0x989b2b1e -[NSView addSubview:] + 411
    17 com.apple.AppKit 0x989dd0db -[NSFrameView addSubview:] + 60
    18 com.apple.AppKit 0x98a48505 -[NSThemeFrame _showHideToolbar:resizeWindow:animate:] + 96
    19 com.apple.AppKit 0x98a48498 -[NSThemeFrame _showToolbarWithAnimation:] + 195
    20 com.apple.AppKit 0x98a2efa6 -[NSWindow _showToolbar:animate:] + 117
    21 com.apple.AppKit 0x98a2d249 -[NSWindow setToolbar:] + 738
    22 com.apple.ozone.framework 0x00c93045 -[OZCanvasView awakeFromNib] + 741
    23 com.apple.CoreFoundation 0x939829b4 -[NSSet makeObjectsPerformSelector:] + 196
    24 com.apple.AppKit 0x9899621c -[NSIBObjectData nibInstantiateWithOwner:topLevelObjects:] + 1566
    25 com.apple.AppKit 0x989941f4 loadNib + 257
    26 com.apple.AppKit 0x98993848 +[NSBundle(NSNibLoading) _loadNibFile:nameTable:withZone:ownerBundle:] + 831
    27 com.apple.AppKit 0x989934fe +[NSBundle(NSNibLoading) loadNibFile:externalNameTable:withZone:] + 158
    28 com.apple.AppKit 0x98a231e7 -[NSWindowController loadWindow] + 223
    29 com.apple.AppKit 0x989b9f76 -[NSWindowController window] + 89
    30 com.apple.ozone.framework 0x00814cbc -[OZObjCDocument showWindows] + 156
    31 com.apple.AppKit 0x98d38712 -[NSDocumentController(NSDeprecated) openUntitledDocumentOfType:display:] + 148
    32 com.apple.ozone.framework 0x00ab3909 -[OZDocumentController openUntitledDocumentOfType:display:] + 233
    33 com.apple.ozone.framework 0x00ab3ab0 -[OZDocumentController newDocument:] + 80
    34 com.apple.ozone.framework 0x00b1c502 -[OZWelcomeScreenController performClose:] + 338
    35 com.apple.AppKit 0x98a14c46 -[NSApplication sendAction:to:from:] + 112
    36 com.apple.prokit 0x001bcc77 -[NSProApplication sendAction:to:from:] + 127
    37 com.apple.AppKit 0x98af4465 -[NSControl sendAction:to:] + 108
    38 com.apple.AppKit 0x98aeff12 -[NSCell _sendActionFrom:] + 169
    39 com.apple.AppKit 0x98aef209 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 1808
    40 com.apple.AppKit 0x98b448a1 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 524
    41 com.apple.prokit 0x001fd4d0 -[NSProButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 539
    42 com.apple.AppKit 0x98aedc5f -[NSControl mouseDown:] + 812
    43 com.apple.AppKit 0x98aebc68 -[NSWindow sendEvent:] + 5549
    44 com.apple.prokit 0x001e182b -[NSProWindow sendEvent:] + 264
    45 com.apple.AppKit 0x98a04817 -[NSApplication sendEvent:] + 6431
    46 com.apple.prokit 0x001bebb0 -[NSProApplication sendEvent:] + 1901
    47 com.apple.motion 0x0000848b 0x1000 + 29835
    48 com.apple.AppKit 0x989982a7 -[NSApplication run] + 917
    49 com.apple.prokit 0x001bef5c NSProApplicationMain + 326
    50 com.apple.motion 0x00005881 0x1000 + 18561
    51 com.apple.motion 0x00002ad6 0x1000 + 6870
    Gareth Randall replied 15 years, 5 months ago 2 Members · 1 Reply
  • Gareth Randall
    April 6, 2011 at 5:43 am
    Hi Leng,
    Those logs are all Greek to us too! They are of no practical use on a forum like this, they’re only decipherable by Apple programmers.
    First off – your Mac definitely supports the minimum spec, yes? You’re not (for example) trying to run Motion on a pre-2009 MacBook using Intel integrated graphics?
    If Motion is habitually crashing on startup, then it’s possible that it’s the ProKit 6.0.1 update that’s causing it. Even though 6.0.1 doesn’t contain any Motion-specific stuff, many people have reported major problems with Final Cut Studio apps after installing it (and many others haven’t).
    So I guess the first step, if you do have ProKit 6.0.1, is to follow the instructions here.
    If you don’t have it, or you’ve reverted unsuccessfully to a previous ProKit version, then you need to completely uninstall Motion (using FCS Remover) and reinstall. If *that* still doesn’t fix it, you might want to try a complete ground-up reinstallation of OS X.
