Activity › Forums › Apple Final Cut Pro Legacy › Motion clips rerendering
  • Motion clips rerendering
    Posted by Mick Haensler on October 16, 2008 at 6:44 pm
    Hey everyone. I searched the forum and couldn’t find a direct answer to this. I have a project with a lot of clips done in Motion. The project is a 1080 x 1920 timeline. All of the motion projects are created in the same format. However, when I bring the Motion projects into the FCP timeline, FCP rerenders them every time I make the slightest change. I’ve tried rendering them out of Motion as MOV files and bringing the Motion project straight into the FCP timeline with the same result. What am I doing wrong. This is costing me a lot of time. Thanks for any help.
    Mick Haensler
    Higher Ground Media
    Mick Haensler replied 17 years, 11 months ago 2 Members · 2 Replies
  • David Bogie
    October 16, 2008 at 10:02 pm
    [Mick Haensler] “However, when I bring the Motion projects into the FCP timeline, FCP rerenders them every time I make the slightest change. I’ve tried rendering them out of Motion as MOV files and bringing the Motion project straight into the FCP timeline with the same result. “
    If I read you post correctly, the problem is most likely the sequence settings in FCP do not match precisely the settings of the Motion files.
    But you haven’t said what is actually rendering in FCP (and it’s quite confusing without lots of experience). is it the timeline that’s rendering or the Motion file? Since your’e in FCP, it’s probably the timeline. Is the .motn or QT movie on top of another layer? Then, yes, of course it has to render. Every pixel under the Motion clip is being altered by the Motion clip.
    If you are importing .motn files, they’re not really rendered yet. The best you can get as a preview is the best your machine’s GPU can deliver.
    bogiesan
  • Mick Haensler
    October 17, 2008 at 4:01 pm
    Thanks for the response Dave. It’s the file itself that is rerendering, not the entire timeline. I do have the files layered, It’s also happening when I move around a text clip that was created in FCP in the timeline itself. You’ll have to excuse my ignorance as I’m new to FCP coming from a real time no render edit suite.
    Sounds like something I’m just going to have to live with.
    Mick Haensler
    Higher Ground Media
