Activity Forums Apple Final Cut Pro Legacy Motion Bug in FCP
  • Motion Bug in FCP
    Posted by Rob Lalonde on April 6, 2009 at 1:37 pm
    Hello,
    I am experiencing a bug that when I bring in a .motn file in to my Uncompressed 8bit timeline, some of the graphics don’t show up. When I open it in Motion, it is fine, but when I look at it in FCP, those layers aren’t there, usually it’s just the background.
    I’ve tried, re-saving, reconnecting and a few other things. Sometimes when I close FCP and re-open, the files will update fine, but not all the time.
    The problem is system wide and not just project or file specific.
    Any Ideas are welcome
    FCP 6.0.5
    OSX 10.5.6
    3ghz quad
    Kona LHe 6.0.1
    6TB HDOne
    Have a good one,
    Rob LaLonde
    Rec and Tek Media, Inc.
    Rob Lalonde replied 17 years, 1 month ago 2 Members · 2 Replies
  • Jason Diebler
    April 6, 2009 at 5:20 pm
    Are you roundtripping the motn project? Are your Motion/FCP project settings the same (resolution/frame rate)? Are you using cohesive versions FCP 6, Motion 3? Done all your Pro App updates?
    Try creating a slug in FCP, same time duration as your current motn clip, send to motn project, copy your layers from the original motn project into the new “roundtripped” project, save, and see if that works…
    If it still gives you issues, consider exporting Animation + Lossless from Motion and import into FCP.
  • Rob Lalonde
    April 7, 2009 at 3:39 pm
    Sometimes, but not all the time…
    Yes, but sometimes I bring in 720/30p and scale it to the SD project.
    It happens with stills as well though.
    Yes
    I’d just re-boot to try and get it back before I’d do this, it really doesn’t solve anything.
    But, this defeats the purpose and doesn’t help fix the problem.
    Have a good one,
    Rob LaLonde
