Activity › Forums › Avid Media Composer › Motion Blurring in DVD – Avid Xpresss Workflow
  • Motion Blurring in DVD – Avid Xpresss Workflow
    Posted by Mike Becher on August 3, 2006 at 3:37 pm
    I’m encountering serious motion blurring when I playback a DVD through a set-top player NTSC monitor. My workflow is to export out of Avid Xpress Studio HD as a quicktime reference file, encode in Sorenson Squeeze, and author in Avid DVD by Sonic. My encoding settings are MPEG-2, Elementary, 2-pass VBR, total data rate 9300 (audio 1536, video 7800), NTSC 720 x 480, frame rate 29:97, Field encoding – bottom field first, I frame rate – 6. What’s driving me crazy is that I was able to successfully encode a previous version of this without the motion blurring at the same encoding settings. I had to go back to modify a Marquee Animation (under render options, select suppress vertical jitter)and then re-export and re-incode. I haven’t gotten a clean version yet. I’ve reincoded a zillion (actually only a million) different ways with the same result. I haven’t been able to determine if this is an Avid issue, Squeeze, or Avid DVD. I did go back and re-incode the original trouble-free exported sequence and am having the same motion-blurred results. The only variable that has changed is the Marquee setting, but isn’t this setting limited to Marquee titles and animations, and not the entire sequence? Anyone have any ideas? (since I’m not sure where the problem lies, I’m submitting this in both DVD authoring and Avid Editing forums). Thanks in advance for your help.
    Dan O’brien replied 20 years, 1 month ago 2 Members · 1 Reply
  • Dan O’brien
    August 8, 2006 at 11:24 pm
    try doing a video mixdown of your sequence and exporting that…
    clip>>Video Mixdown…
    or
    special>>Video Mixdown…
    (depending on your version)
    Dan
    PrEditors.net
