Activity Forums Adobe After Effects Motion Blur Switch CS5.5
  • Motion Blur Switch CS5.5
    Posted by Lisa Talley on August 21, 2012 at 6:04 pm
    Since they’ve made Motion Blur a layer switch, instead of an option in say particle world, I’ve run in to problems trying to use it. Whenever I switch it on/off, nothing happens, I ended up just using the Directional Blur to get a similar effect… However, I’m fairly positive that I’m just missing some key step or element in using it, so I’m curious, has anyone had the same problem?
    Lisa Talley
    Sacramento Video Production
    Lisa Talley replied 14 years ago 2 Members · 2 Replies
  • John Cuevas
    August 21, 2012 at 6:17 pm
    Besides the layers motion blur switch are you enabling motion blur for the composition also? #1 enables motion blur for the layer, but until you press #2 and enable it for the composition it’s turned off. Makes it easier to work if AE doesn’t have to calculate the blur for every frame, just turn it on before rendering.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Lisa Talley
    August 22, 2012 at 6:45 pm
    See, I knew I was over looking some incredibly simple, yet important step. Brilliant, thank you so much for your help!! Much appreciated.
    Lisa Talley
