Activity › Forums › Maxon Cinema 4D › Motion Blur on only specified part of model – possible?
  • Motion Blur on only specified part of model – possible?
    Posted by Brian Murphy on October 21, 2013 at 8:15 pm
    Hey all,
    I have a bird and only with to apply motion blur to the wings, not the body of the bird. Only way I figure I can pull this off is to render in two separate passes – one render with and one render without motion blur, then render out mattes of the wings and composite the two together.
    Anyway to do this “in-camera”? Can I specify a selection tag or use a vertex map to set how strong/weak the motion blur could be?
    Brian
    Brian Murphy replied 12 years, 11 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    October 22, 2013 at 5:45 pm
    I don’t think it’s possible to have different motion blur settings for the same object. Only way I can think of would be to bake the animation to keyframes, split off the wings, and use motion blur tags to limit the moblur to the wings.
  • Brian Murphy
    October 22, 2013 at 6:11 pm
    Thanks Adam – just wanted to make sure.
    Your idea is exactly what I ended up doing…worked just fine.
    Cheers!
