Activity Forums Adobe After Effects Motion Blur issue
  • Motion Blur issue
    Posted by Matthew Angus on February 16, 2012 at 3:59 am
    Hi Guys
    Have a strange occurance when RAM Previewing an animation with motion Blur applied. I have used this effect many times…but for some reaosn this project and my last started having this issue…therefore think it’s something preference/setting wise.
    When I run the RAM preview, the animation doens’t blur as it should but gives a weird duplicted type effect…which is definantely not what I am after. I have attached an image of it a couple of frames into the animation.
    I have also run a render and same event occurs.
    Any help would be much appreciated.
    Cheers, Matt
    Kevin Camp replied 14 years, 6 months ago 4 Members · 3 Replies
  • Angelo Lorenzo
    February 16, 2012 at 4:23 am
    This is a guess, but do you have the little sun-like icon checked for the text layer? That switch rasterizes vector layers… probably has some effect on how motion blur is calculated.
  • Tudor “ted” jelescu
    February 16, 2012 at 9:35 am
    Adjust your motion blur settings to achieve the desired look.
    Under Composition Settings/ Advanced tab, change the Samples Per Frame and the Shutter Angle.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Kevin Camp
    February 16, 2012 at 3:59 pm
    might also be an opengl issue, in preferences>previews uncheck the opengl option for previews, however, if your motion is generated by a random() expression that kind of double image can occur with motion blur.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
