Activity Forums VEGAS Pro Motion blur in Vegas.
  • Motion blur in Vegas.
    Posted by Tevya Washburn on August 14, 2007 at 4:23 pm
    I want to do a motion blur on a person that runs away from the camera. The camera is locked down, just the person moves. I want an effect similar to when Clark runs fast in Smallville. I don’t see a motion blur effect in Vegas, is it possible to do this with vegas? It seems like there should be a motion blur effect, but maybe I’m thinking of some other software. Any help would be appreciated.
    –the Fiddler
    Cactusvac replied 18 years, 11 months ago 3 Members · 4 Replies
  • Jci_pro
    August 16, 2007 at 11:40 pm
    Yes there is. With vegas open click “Ctrl+Shift+B” to get the Video Bus Track, then right click on it, and choose “insert/Remove Envelope” and click on “Motion Blur Amount” You’ll see an Envelope across the timeline, But you’ll also need to use another Envelope called “Video Supersampling” which you get in the same way as the Motion Blur just choose Video Supersampling Instead. Drag the line Upwards as desired on each envelope, note that these envelopes require a lot of Power from your computer, so You’ll need a very fast one.
    Tip: The “Motion Blur Amount” describes it self and the “Video Supersampling” increaces or decreaces the Smoothnes of the Blur effect.
    Hope this helps.
  • Tevya Washburn
    August 17, 2007 at 4:01 pm
    Yeah, that helps a ton. Thanks JCI_pro! I thought my thread was gone & wouldn’t be noticed. Really thanks a lot, this may save me a ton of time over another method I might’ve used.
    –the Fiddler
  • Jci_pro
    August 20, 2007 at 12:37 am
    You are welcome, I’m glad it was helpful.
  • Cactusvac
    October 9, 2007 at 2:18 pm
    Hello there,
    When I right click the video bus and chose add/remove envelope motion blur amount and supersampling are missing.The only available options are mute, composite level and fade to color.Im on vegas 7.0d.Any help would be greatly appreciated.Thanks.
