Activity › Forums › Adobe After Effects › Motion blur based on tracking info
  • Motion blur based on tracking info
    Posted by S. Marcotte on November 19, 2008 at 8:12 pm
    I’m moving the x and y position of a layer based on tracking information copied onto the layer’s keys. Works well, but I would like to add some motion blur based on that same information. Is there an easy way to do this without a fancy plugin? If not, I suppose I’ll take any inexpensive suggestion out there. Many thanks.
    S. Marcotte replied 17 years, 10 months ago 25,349 Members · 2 Replies
  • S. Marcotte
    November 19, 2008 at 9:25 pm
    By “built-in” you mean the little switch I just discovered on the timeline, right? Where in preferences will I find the shutter? Looked all over. Finally, I can’t seem to find “CC Force Motion Blur” under the effects. I’m using 7.0 pro.
  • S. Marcotte
    November 19, 2008 at 11:23 pm
    The shutter is in the composition settings, advanced tab. It seems to be working fine. Thanks again – S.
