Activity Forums VEGAS Pro Motion Blur after render at different framerate even with disable resample
  • Motion Blur after render at different framerate even with disable resample
    Posted by Ryan Moyer on March 29, 2010 at 3:07 am
    So to produce a “stutter” effect in one of my clips, I used undersample to reduce the framerate of the clip. That means the project is at 29fps and that individual clip is at 14fps.
    When I play it back in the timeline everything looks fine, I get the exact “stutter” effect I was looking for. However once I render the video using the Internet HD 720p 30fps preset, I get a ton of motion blur on that clip. A quick google said that switching that clip’s properties to “disable resample” should make it just drop half the frames instead of blending them, thus eliminating the motion blur. However this did not work, and the motion blur did not improve much if at all.
    Again, the blur is not there when I preview in the timeline, but appears after rendering.
    Matt Crowley replied 14 years, 2 months ago 4 Members · 12 Replies
  • 12 Replies
  • Mark Mccormack
    March 30, 2010 at 11:23 am
    Try right click on the clip and switches – reduce interlace flicker.
  • Ryan Moyer
    March 30, 2010 at 4:19 pm
    That had no effect.
  • Mark Mccormack
    March 30, 2010 at 10:21 pm
    Have you tried changing to progressive scan when you render?
  • Ryan Moyer
    March 30, 2010 at 11:27 pm
    I believe it already is. Field order for the clip is set to none (progressive).
    Which option are you referring to?
  • Mark Mccormack
    March 31, 2010 at 5:46 am
    Its only if you are rendering to mpeg, you can change the field order in the custom tab. If you are rendering to wvm there is no option.
  • Ryan Moyer
    April 1, 2010 at 4:30 am
    Yep, that is already set to None (progressive scan), and I still get the motion blur after render (but not in the preview window).
  • Ryan Moyer
    April 1, 2010 at 5:12 am
    Also, I recently found the “disable motion blur” button on the timeline of the video track, but selecting that (even if I do it for all tracks) doesn’t help either.
    This is ridiculous. Vegas adds motion blur to prevent stuttering with a lower frame rate. But I WANT it to stutter. Why can’t I tell Vegas that?
  • Ryan Moyer
    April 1, 2010 at 5:18 am
    Hmmm, so apparently the clip had someone gotten the field order set back to “lowest first”, which apparently overrides the project settings.
    However, changing it back to None (progressive scan) greatly reduces the motion blur, but at the same time it shows up badly interlaced (the original clip was interlaced). It’s weird because it doesn’t show up interlaced in the preview window, and even weirder because After Effects has absolutely no problem rendering the same clip with no interlacing or motion blur.
  • Ryan Moyer
    April 1, 2010 at 5:23 am
    Ok, I finally got it fixed.
    For anyone out there that comes across this from google, the thing that finally did it was changing interlace method from Blend to Interpolate. This finally got rid of the blur.
  • Danny Jeffery
    June 29, 2012 at 12:46 am
    Hi there,
    I’m having the same issue as you with motion blur on my video, but being fairly newbie at vegas, I’don’t know how to do the above to try and fix it.
    I have Vegas 9 – can you offer some instruction on how to set the interlace method pls?
    Many thanks!
