Activity Forums Apple Motion Motion 5 generator render qualityin in fcpx
  • Motion 5 generator render qualityin in fcpx
    Posted by Imari Childress on April 11, 2012 at 9:20 pm
    Posted this question in January and got no reply. Nobody can answer this??
    When I create a generator/effect etc to use in fcpx, how do I know that the generator is rendering at the highest quality when i play in fcpx? Does that depend on the settings when I save the motion generator?
    For instance, if I’m working in motion at a lower resolution and render quality, will that carry over to fcpx?
    How do I make sure that motion generators are rendering at their highest quality in fcpx?
    Jarek Komárek replied 13 years, 6 months ago 4 Members · 4 Replies
  • Simon Ubsdell
    April 13, 2012 at 3:30 pm
    When you use a Motion template inside FCPX you will always get the highest possible resolution regardless of how your Motion project is set up.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Jarek Komárek
    March 8, 2013 at 7:52 pm
    I actually don’t get the best quality. When rendered right from Motion, the quality is apparently better. I didn’t find any mention of quality control in the manual. I’d even expect quality parameters such as motion blur on/off switch available for publishing. Is this possible?
  • Mark Spencer
    March 11, 2013 at 2:06 pm
    No, you can’t publish motion blur parameters.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Jarek Komárek
    March 12, 2013 at 5:07 pm
    Too bad. Motion Blur can solve unpleasant flickering. Maybe in next version? 🙂
