Activity › Forums › Apple Final Cut Pro › Motion 5 FCP Title wont key in FCPX
  • Motion 5 FCP Title wont key in FCPX
    Posted by Bill Nahlik on November 21, 2013 at 3:33 am
    I built a lower third title in motion 5 (using the FCP title preset). When I look at it in Motion over transparent, it keys properly.
    I publish to FCPX, it looks right in the title browser, but when I scrub over it, the key is inverted. That is, the background of the lower third is transparent, revealing the underlying video and the rest of the screen is black. The type shows in the proper place and is modifiable.
    When I drop it on my timeline, I get the same inverted key problem.
    I’ve tried different compositing modes in FCPX with no luck.
    Bill Nahlik replied 12 years, 10 months ago 3 Members · 4 Replies
  • John Fishback
    November 21, 2013 at 2:57 pm
    In Motion check the drop down menu: View > Channels > and see if Inverted Alpha is engaged.
    John
    MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
    FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
    Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
  • Andreas Kiel
    November 21, 2013 at 3:11 pm
    I don’t know what title you created. But a common error is to have a drop zone in there.
    -Andreas
    Spherico
    https://www.spherico.com/filmtools
    X-Files Pro, tools for working with FCPX
    https://www.spherico.com/filmtools/X-Files/index.html
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
  • John Fishback
    November 21, 2013 at 4:25 pm
    If Motion was setup with inverted key, that’s how FCPX will play it. Just a thought.
    John
  • Bill Nahlik
    November 21, 2013 at 9:03 pm
    When I built the lower third in motion, I used the drop zone from the template, resulting in the original problem.
    I rebuilt it, not using the drop zone, and it worked perfectly.
    Who knew?
