Activity Forums Apple Motion Motion 5: exported file doesn´t look like my project
  • Motion 5: exported file doesn´t look like my project
    Posted by Gernot Goebel on December 1, 2011 at 2:08 pm
    Hello,
    I exported a piece of video which is a black circle which is increasing size, in the end the screen is black. I did this with an animated camera. pretty simple.
    The crazy thing about it is, when I export it, the timing is not correct. It starts fast and becomes slow. In my project, it is a linear movement, done with keyframes. When I do a RAM preview, it looks exactly like it should, linear movement.
    Where is my mistake?
    Gernot Goebel replied 14 years, 9 months ago 1 Member · 1 Reply
  • Gernot Goebel
    December 1, 2011 at 2:25 pm
    Ok, I solved my problem:
    I had a masking circle in the project in the same place but with different animation settings, so that´s what I got when I rendered it out: both circles (the black one and the one which I used to mask another layer) went to the export, because I had forgotten about the masking circle. I deacitivated it and now it behaves like it should
    strange though: Why didn´t I see that in RAM preview?
