Activity › Forums › Apple Motion › Motion 3 subpixel rendering
  • Motion 3 subpixel rendering
    Posted by Paul Ingvarsson on June 15, 2007 at 9:47 am
    Hello,
    I’m doing some very simple text floats across screen with Motion 3. The movements are created using the throw behavior and the edges of the text are ‘creeping’. I recognise this from operating DS Nitris and needing to use subpixel rendering. Is this something Motion can do? or am I better off making a double size comp and scaling down afterwards to get better motion on my edges?
    Many thanks,
    Paul
    Doyle Rockwell replied 19 years, 3 months ago 3 Members · 3 Replies
  • Noah Kadner
    June 15, 2007 at 5:17 pm
    Are you looking at the final output with all quality settings to high or a lower res proxy preview?
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Paul Ingvarsson
    June 16, 2007 at 7:08 am
    No, I’ve double checkd al my output settings when I choose to export the project to an animation quicktime. 32 bit float, Full res and best quality render. I don’t have motion blur switched on because the text is moving very slowly and adds loads to the rendering time.
    Paul
  • Doyle Rockwell
    June 16, 2007 at 1:19 pm
    Heya,
    Motion blur definitely adds to the render time, but so does using 32-bit float. Are you doing any particular operations that require float? It adds a lot of overhead to the processing, and doesn’t often make a difference.
