Activity Forums Apple Motion Motion 3 spacebar strangeness
  • Motion 3 spacebar strangeness
    Posted by John Phillips on April 7, 2008 at 11:41 am
    Hello Folks
    I migrated from a MBP to a 2008 MP last week. Latest software in MP. Motion worked fine on the new machine (a couple of test projects) then suddenly the spacebar began activating/deactivating layers in the timing and project windows. Over on the Apple discussions, one person said this was normal on his machine, another said “not good.” I did all the normal prefs dumping etc. Strange thing is, when I log into a user account which was non-migrated, Motion works as expected (and as it did on the laptop -spacebar only does playback and play-from -beginning) I fiddled with the Commands menu, copying a duplicate from the ‘good’ users account to the migrated account with no success. Another strange anomaly I discovered while delving into the spacebar problem – the “set timeline row size” icons don’t work anymore- stuck on smallest and when I drag them larger, they snap back to small. Weird!
    Any advice on getting Motion back to it’s previously working state? Seems to have happened around the time I updated to 3.0.2. Should I try reinstalling Motion? If so, how? If I throw out the program, will the install disc replace all components?
    Thanks, John
    John Phillips replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
