Activity Forums Apple Motion Motion 3 is cutting off, top of text, when importing into FCP 6 or when exporting? HELP!!
  • Motion 3 is cutting off, top of text, when importing into FCP 6 or when exporting? HELP!!
    Posted by Sebastian Knight on September 3, 2007 at 1:53 am
    I am having a problem with Motion 3, when I create text and bring in into FCP 6 or export it, it is cutting off the tops of letters. I am working in DV , this never happened in Motion 2. What is wrong? Is it possible I have a setting wrong?
    Sebastian
    Thank You in advance for taking the time to read and reply to my Post.
    Sebastian
    Sebastian Knight replied 18 years, 12 months ago 2 Members · 2 Replies
  • Gabriele De simone
    September 11, 2007 at 2:15 pm
    Enclosing the text into its own Group (aka Layer) if necessary, then go to the Group properties and enable the “Fixed Resolution” checkbox.
    By doing so, you are telling Motion that no matter what the boundary of the text is, it should always render the text in an image that has a fixed size (normally: the frame size). This trick often gets rid of unwanted clipping when rendering Motion projects in FCP/DSP/Compressor. I hope it helps in your case too 🙂
    Gabe
    Noise Industries
    https://www.noiseindustries.com
  • Sebastian Knight
    September 11, 2007 at 11:27 pm
    This did not fix it. Thank you.
    Sebastian
    Sebastian
