Activity Forums Boris FX Sapphire Morphing with Sapphire?
  • Morphing with Sapphire?
    Posted by Allan Thrush on July 6, 2009 at 7:38 pm
    Hi…
    Quick question. My producer is trying to achieve an effect where he wants to morph an object which is spinning on a turntable, into another object spinning on the same turntable (locked off shot).
    He doesn’t want to do just a simple dissolve between the two objects.
    We’re running Sapphire V2 on an Avid Symphony Nitris…
    a)is it possible to achieve this effect with V2 plugins?
    b) is there a plugin on V3 or higher that would achieve this effect with greater ease?
    or can you recommend some software or technique that would do the trick?
    Cheers! (and thanks in advance…)
    Allan
    Allan Thrush
    Editor
    Zoom Communications
    Allan Thrush replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
