Activity Forums Adobe After Effects Morphing motion / plugins?
  • Morphing motion / plugins?
    Posted by Rafael Metz on June 26, 2014 at 8:28 pm
    Hi there,
    I want to morph footage with motion – people turning their head etc.
    As far as I´ve researched there are two plugins: RE:Flex and BCC Morph.
    I was wondering why there are not so many resources for morphing, but ok…
    Can anyone tell me the difference (aside from $595 and $199) between these plugins?
    Which way/and or plugin is the best to morph moving footage?
    Maybe someone has additional good tips, techniques or suggestions concerning morphing.
    Regards
    Rafael
    Erik Lindahl replied 12 years, 2 months ago 4 Members · 4 Replies
  • Jp Pelc
    June 26, 2014 at 9:15 pm
    I don’t know about those plugins, but if you are looking to do some morphing on the cheap you can try this technique:
    https://forums.creativecow.net/readpost/2/1052130
    Maybe just mask the area you want to transform?
  • Kevin Camp
    June 26, 2014 at 10:09 pm
    here’s another method:
    https://library.creativecow.net/articles/stern_eran/Simple_Morph.php
    also, i think re:flex has a free demo (not sure about bcc) so you could try it out.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Rafael Metz
    July 1, 2014 at 9:23 am
    Thank you!
    My problem is morphing a moving picture – stills are no real problem. I don´t know if Re:Flex or BCC can handle moving images in that sense that you can change parameters within time and the morph will know what to do 🙂
  • Erik Lindahl
    July 6, 2014 at 10:38 am
    RE:Flex can give you great results and can be used for morphing and image distortion. For me it’s a must have plug-in. Just yesterday I used it to fix a damaged frame in a shot using the adjusting frames before and after to create a new one.
    The only thing I lack is the ability for AE to track motion paths (not the motion shape-solution they have now, it’s quite sub-par) or for a third party to send motion path data to AE reliably. The trick with RE:Flex is that each vertex-point has to have a corresponding point in the before and after image for the morphs to be calculated correctly.
