Activity › Forums › Adobe After Effects › Morphing between layers of video
  • Morphing between layers of video
    Posted by Ryan Sereno on February 28, 2012 at 11:35 pm
    I’ve built a rig which holds 2 camera’s side by side to film simultaneously. I want to alternate every frame or two between the 2 sets of footage. I have done this by key framing the opacity of the top layer, but this is giving me a very jerky effect. This is why I want to add the morphing in.
    This is a music video in which the effect is used
    https://vimeo.com/36867236
    To do the morphing between the 2 layers, I think I have to increase the frame rate so that there are available frames for the morphing to happen in the same amount of time. Or I could keep the frame rate and the morphing in between frames will just slow the video content. I don’t have a preference between the two methods but I think the slowing of the video would give a good effect.
    My question is, how do I morph between 2 frames on separate layers, and back again to give the alternating effect?
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Ryan Sereno replied 14 years, 6 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    February 29, 2012 at 12:42 am
    My first thought, without resorting to awkward tricks would be to look into GenArts Sapphire and some of their available transition plugins. They are transitions for after effects that will morph between two target layers.
  • Ryan Sereno
    February 29, 2012 at 12:51 am
    Thanks, but I don’t want to have to buy an add on or plugin. This is just a low budget project I’m working on.
    I’m trying to figure out if there’s a way I could use pixel motion in frame blending.
  • Walter Soyka
    February 29, 2012 at 3:37 am
    Render out your existing strobed version, then re-import it and retime with pixel motion.
    Walter Soyka
  • Ryan Sereno
    February 29, 2012 at 11:41 pm
    That’s actually the effect I was looking for. I don’t know why I didn’t think of that myself
    thanks!
