Activity › Forums › Adobe After Effects › morph
morph
Posted by Patricia Contreras on June 29, 2009 at 2:49 pmdid someone knows witch is the best software to morph images, I use to use elatic reality in the past, but that software dosent exists any more. I would apreciate any sugestions.
patricia.
Matthew Woods replied 17 years, 3 months ago 4 Members · 3 Replies -
Kevin Camp
June 29, 2009 at 3:39 pmeran stern did a tutorial using a creative way to create a morph in ae with no extra effects, you might check that out:
https://library.creativecow.net/articles/stern_eran/Simple_Morph.php
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Peter Litwinowicz
June 29, 2009 at 5:09 pmIf you are interested in something like what what you have used in the past, you should check out our RE:Flex plugin for AE. It uses free-form splines (using AE’s masks, so you don’t have to learn a new spline interface!)
https://www.revisionfx.com/products/reflex/
Features: https://www.revisionfx.com/products/reflex/features/Note that we are the only morpher on the market that uses an automatic alignment feature (using optical flow, a type of motion estimation) to help improve the results of your morphs.
There is a free download as well, so you can try it out (make sure to read the manual that is installed when you download the plug-in).
Pete LItwinowicz
https://www.revisionfx.com -
Matthew Woods
June 30, 2009 at 5:07 pmIf you are on a mac, norrkross’s morphx software is an excellent free morphing program to morph between two stills:
https://www.norrkross.com/software/morphx/morphx.php
