Activity Forums Zaxwerks more than 8 layer maps?
  • more than 8 layer maps?
    Posted by Mike Rother on May 5, 2008 at 7:46 pm
    I’m doing a “video wall” effect in Invig. I have about 16 screen shapes and I’m wondering if I can add layer maps to each of them. Seems like the limit is 8. Is there some way to pre comp or add more layer maps?
    thanks
    MR
    Mike Rother replied 18 years, 4 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    May 6, 2008 at 12:40 am
    Hi Mike,
    It depends on how you made your video wall in the first place. If you make all of the screens as one compound object in Illustrator then use that in Invigorator, you can make a precomp with all 16 videos playing in it and apply that as a layermap to all 16 monitors at a time. You can still control each movie individually from within the precomp.
    Does this help?
    Jon
  • Mike Rother
    May 6, 2008 at 3:24 am
    ahhhhhh
    totally. Using the screen objects as a compound object makes sense.
    thanks for the quick reply.
