Activity Forums Apple Final Cut Pro Legacy More than 4 multi cam angles won’t show up at the same time?
  • More than 4 multi cam angles won’t show up at the same time?
    Posted by Peter Vandall on October 28, 2011 at 12:41 pm
    Hi I am working on a shoot with 5 camera angles. Only 4 show up, and if I want to see the 5th, I have to stop Final Cut and click an arrow in the lower right hand corner of the viewer, select the angle, and hit play again.
    What gives? Is there a way to display more than 4 angles simultaneously?
    Thank you!
    Peter
    Alex Elkins replied 14 years, 10 months ago 2 Members · 1 Reply
