Activity › Forums › Apple Final Cut Pro › More stuttering on export
Posted by James Ewart on October 3, 2012 at 2:15 pmexporting direct to H264 creates stuttering here too…converting it to 720P optimum Vimeo settings with Streamclip makes it worse.
Buggy wuggy!
James Ewart replied 13 years, 12 months ago 2 Members · 3 Replies -
James Ewart
October 3, 2012 at 2:25 pmusing compressor seems to alleviate the problem…but it’s a workaround isn’ it and there seem to be reports of this going back over a year and nothing addressed by Apple.
So we have to use Compressor it seems.
Tony Brittan
October 4, 2012 at 12:59 amI did a direct share to Vimeo the other day and it looks great! I then went into the project folder in finder and inside the shared folder was a copy of what was sent up and again, it looks great. Maybe try that?
James Ewart
October 4, 2012 at 6:15 amThanks…yes probably the way to go but it takes a while doesn’t it. My preferred worklow was get the thing out of FCP ASAP creating just a ref movie. The convert with Streamclip and upload thus freeing up FCP toget on with the work.
Also it seems to create.mov files using its Vimeo setting whereas had thought (or at least Vimeo stat) that they prefer.mp4 files but have now checked the .mov file and it is an H264 so probably best to go auto as you suggest.
Thanks for the tip.
So we save loads of time in FCPX on import and rendering but when it comes to exporting we seem to have taken a bit of a step back in time.
