Activity Forums Apple Final Cut Pro Legacy more render issues..help
  • Jeremy Garchow
    October 8, 2007 at 8:06 pm
    I don’t understand.
    You are working with three layers, and then when you move a layer you have to rerender? This makes sense as you are changing the relationship between the layers and the rendered clip.
  • Travisl
    October 8, 2007 at 9:14 pm
    what happens, i have three timelines stacked. i adjsuted one time line to align with the othet two. then i half to render agin??
  • Joe Murray
    October 8, 2007 at 9:15 pm
    As Jeremy says, this is normal.
    Unless you are using, feathers and moves you can get around it by switching “RT” in the timeline to Dynamic. It will look like poopy but will allow you to approximate the relationship between the clips- then render at the end.
