Activity › Forums › Apple Final Cut Pro Legacy › More Quicktime playback issues
  • More Quicktime playback issues
    Posted by Martin Sterling on April 7, 2006 at 11:57 pm
    Im running FCP5.0.4 and QT7.1 and sometimes I have problems playing a clip in the viewer as well as the canvas. For instance, sometimes when I switch from canvas to viewer and press play the clip will play several frames and stop. I will have to press play again to make the clip continue. Also sometimes I will press play in viewer and the clip will play for several seconds and the picture will freeze but the timeline will advance. I also experienced this problem with the QT update. What could be the problem?
    Also, Upon capturing footage I sometimes get the prompt saying my Sample Rate for my footage and what I captured do not match. I am capturing DV and my Easy setup is at DV48KHZ and when the clip comes in it is 48 KHZ and in sync. What could be causing this prompt.
    THANK YOU IN ADVANCE
    G5 Dual 2.0 GHz processor, OSX.3.9
    Martin Sterling replied 20 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
