Activity Forums Maxon Cinema 4D More polygon subdivisions
  • More polygon subdivisions
    Posted by Brian Stenson on November 10, 2008 at 5:18 pm
    Basically what I have done is extruded a path. made it editable and I am trying to apply a bulge to it to make it a convex shape. Its a logo that I want to spin.
    the problem is that when I flatten it the caps are too flat to be able to bulge smoothly. is there any quicker way to apply a mesh or something over the model that will give more polygons otherr than lots of bridge points.
    Hope someone can help.
    Brian
    Brian Stenson replied 17 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    November 10, 2008 at 6:00 pm
    set the caps in the extrude to be Triangles or Quadrangles then check off Regular Grid and set the width to something small enough to give you a bulge. That will work if you don’t bulge/distort too much (if you do the edges can look nasty)
  • Brian Stenson
    November 11, 2008 at 10:29 am
    Thats perfect thanks a million. There is always one more little box to be clicked to get things just looking right.
    Brian
