Activity Forums Apple Final Cut Pro Legacy more perplexing capture problems
  • more perplexing capture problems
    Posted by Edwin Gendron on May 30, 2007 at 12:47 pm
    hi,
    I’m also having capture problems. worked fine in past, now “dropped frames” happens very quickly and assuredly. have tried 2 different hard drives and result is same.
    also works fine if I ONLY import video (no audio)
    using:
    powerbook G4 (only 1 firewire port)
    FCP HD 4.5
    different dv cameras
    anyone have an idea?
    gendroned
    Rainer Wirth replied 19 years, 3 months ago 2 Members · 1 Reply
  • Rainer Wirth
    May 31, 2007 at 3:01 pm
    How much speed of the Powerbook have you got?
    Did you update shortly?
    Amount of Ram?
    Firewire 400?
    Settings in FCP4.5?
    Rainer
