Activity Forums Apple Final Cut Pro Legacy more non drop to drop frame timecode questions
  • more non drop to drop frame timecode questions
    Posted by Justin Montana on August 5, 2009 at 9:15 pm
    I’ve searched through the posts and found some great info on the topic of going from 23.98 NDF to 29.97DF. Here is my problem: I recently sold a program and need an internatioal version that includes timecode cues for text and narration and such. Unfortunately, all of the timecode cues were given from the 23.98 timeline and so after mastering to HDCAM they are all off by a few seconds. I’ve tried using timecode calculator and making a 29.97 DF timeline in final cut and dragging the reference quicktime file into there. The problem is Final Cut gives me different numbers than the calculator, not by a lot but a couple seconds. Which one should I trust? The TRT seems to come out the same on both, but all of the other cues are different. Any help on this would be greatly appreciated!
    John Fishback
    replied 17 years, 1 month ago
    2 Members · 1 Reply
  • John Fishback
    August 5, 2009 at 9:30 pm
    Why not get a timecode burn from the HDCAM and use that?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
