Activity › Forums › Adobe After Effects › More motion paths in Particular
  • Emmett Brown
    December 7, 2017 at 6:42 am
    Not really, as far I know motion paths must have name Motion Path 1-9 and I can’t change it like emitter or shadowlet. So new particular still will be referring to the same motion paths layers. Or I’m missing something?
  • Mark Whitney
    December 7, 2017 at 9:45 am
    Perhaps a bit more detail. What version are you using & where in Particular’s UI panel are you trying to add?
  • Emmett Brown
    December 7, 2017 at 10:34 am
    Particular 3, AE 2018. Motion Paths in Air submenu. There are only 9 paths to select (layer with light motion), and I’m searching for a trick to add more of them ????
  • Mark Whitney
    December 7, 2017 at 7:04 pm
    Ah. Never used that feature so never notice the limitation.
    Expanding on Dave’s comment, I suspect instead of adding a 2nd instance or Particular to your comp, you’ll instead have to first duplicate your comp with the first 9 lights & rename it so you can use it as a pre-comp. In this new comp, delete the original motion path lights (probably anything else not contributing to the Particular effect) & now add your new lights with the needed name (recycling your numbers) so you can then add them into the slots. Drag this new comp into the original.
  • Emmett Brown
    December 8, 2017 at 10:19 am
    Yeah, precomp is a way to go. In this particular project, I still need to render it first before post production (I need to implement those to Element 3d), so for now I just copy whole composition and add new paths (kinda your way). It works for now because paths aren’t intersecting, if so, then precomp could work better 🙂
