Activity › Forums › Adobe After Effects › More Motion Blur steps?
  • More Motion Blur steps?
    Posted by Alejandro Torres on June 19, 2008 at 2:30 pm
    Hi.
    I just noticed that motion blur is giving just two steps (i.e. it makes it look as if the image was just duplicated). Is there a setting I can adjust to make the motion blur more realistic?
    Thanks in advance
    Alejandro
    Alejandro Torres replied 18 years, 3 months ago 2 Members · 2 Replies
  • Kevin Camp
    June 19, 2008 at 2:44 pm
    in cs3, in the comp settings>advanced tab you have control over the number of samples… the defaults should be 16 samples per frame and 128 for adaptive sample limit.
    if you used the force motion blur effect (needed because some effects won’t use ae’s native motion blur) you can set the number of samples in the effect.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Alejandro Torres
    June 19, 2008 at 3:03 pm
    Thanks a lot, it was set to two samples, I don’t know why.
