Activity Forums Adobe After Effects more lighting troubles
  • more lighting troubles
    Posted by Ben Weller on October 29, 2008 at 8:43 pm
    hello there. does anyone know if theres a way to change the distance the light from a light source travels?
    ive got a spot light source shing on my 3d layer, but the angle its at is lighting something up that wouldnt be lit up (if it was actually a mile or so away as im trying to make it look, rather than the thousands of pixels it actually is)
    i dont want to change my angle, so im wondering if theres a way to just make the light not go so far? like in reality where the further you are from a light source the weaker it is?
    cheers.
    David Bogie replied 17 years, 10 months ago 3 Members · 2 Replies
  • Kevin Camp
    October 29, 2008 at 8:25 pm
    i don’t think you can set fall off like that for a spot light within the light settings (at least not in cs3), but here is a link to how to do it with an expression on the 3d layer that you want affected by the fall off…
    https://www.motionscript.com/design-guide/falloff.html
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • David Bogie
    October 29, 2008 at 9:36 pm
    Scripts! Run for you life!
    Kevin’s suggestions are always more elegant than anything I can come up with but I was going to merely suggest you mask off the light with a gobo, an intervening and perhaps moving element that blocks light but does not cast a shadow.
    bogiesan
