Activity › Forums › Blackmagic Design › More jerky symptoms
  • More jerky symptoms
    Posted by Mark on November 27, 2005 at 3:37 pm
    I know this issue was raised earlier, but my jerky issue…. in addition to the sudden and erratic playback issue in the time line is intermittent with captures as well. The affected capture sometimes produces an error message re”timecode break, but there is no timecode break. When I recapture the clip the jerky symptom is not at the same point. While changing to BlackMagic in effects handling solves the issue in timeline playback, it does not help with the capture issue. This has only been a problem in 10bit uncompressed mode… but quite persistent, sometimes compromising 50 – 60 % of a reconformed 10bit uncompressed online edit.The captures are from digibeta and beta sp. g5 2ghz, 10.4.3 fcp5.03 decklink
    Mark replied 20 years, 10 months ago 3 Members · 6 Replies
  • Kristian Lam
    November 28, 2005 at 6:14 am
    Hi Mark,
    Could this be a drive speed issue? What sort of storage are you capturing and playing back from? Have your tired the Disk Speed test and what results did you get?
    regards
    Kristian
    Blackmagic Design
  • Luke Maslen
    November 28, 2005 at 6:35 am
    Hi Mark,
    We’ve seen a number of instances where a disk speed issue has caused “timecode break” warnings. Even if your disks are usually fast enough, you might observe this error if your disks are beyond a critical capacity theshold (eg 80% full), or have become highly fragmented from many batch captures or if antivirus software is slowing down your Mac. It is worth considering these factors even if a disk benchmark seems to indicate adequate performance.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Mark
    November 28, 2005 at 8:04 pm
    Hey thanks guys. I have a swiftdata in the g5 and this project is using a raid 0 with about 39% of capacity available but does seem a lot slower than when I first installed it. I am getting read-70 write-40 (slower than my offline Lacie Big disk) So would you suggest Disk warrior? I really haven’t been defragging much in the past couple of years.
  • Kristian Lam
    November 28, 2005 at 10:44 pm
    Hi Mark,
    The best way to “defrag” will be to move everything out of the drive. Reformat, then move the back in.
    Drives will slow down (sometimes very dramtically) as they get filled.
    regards
    Kristian
    Blackmagic Design
  • Luke Maslen
    November 29, 2005 at 1:12 am
    Hi Mark,
    I’m a big fan of DiskWarrior but it is not used for defragmentation of files. Kristian’s suggestion of copying files off on to another disk, then erasing the RAID and then copying the files back on would be the fastest and safest way of defragmenting the disk. There are a few file optimization utilities available but they take a very long time to move large video files around and I’m not aware of any of them being fail safe. DiskWarrior will sometimes provide a speed boost as it optimizes the directory structure, which is worth doing, but that is different to optimizing the location of the files on the hard disk.
    As a single SATA disk reaches about 80% capacity, it may slow down to around 50% of its speed when empty. This is normal and the more disks you RAID together, the less this slow down will be. A lot of DeckLink users are using 2-disk SATA arrays and these are usually fine but can still underperform when they become too fragmented. It is useful to have a spare disk or two available so you can copy files of the disk array and erase it periodically if it is becoming too slow.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Mark
    November 30, 2005 at 1:42 am
    Thanks guys… well I have had some drive problems in the past month …(one disappeared from the raid and left the material on it lost in it’s wake) and now I notice that even when I completely reformat the drives and stripe again, I am getting pretty slow write speeds… 50 vs read @ 120 and still getting the jerky captures with 99% of the drive capacity available. Do these drives wear out? Geeez only had em a year or so.
