Activity Forums JVC Cameras More high res photos and info on HD100 etc
  • More high res photos and info on HD100 etc
    Posted by Guy Barwood on April 10, 2005 at 10:03 am
    https://www.filmimaging.com/articles/viewarticle.jsp?id=31724-0
    Ok Ken, let me be the first to say I am dissapointed about the lack of 4 channels of audio pre-release docs detailed. It would have been very very handy, I guess it’s too late now to hope for any changes 😉
    My biggest query is that of colour space though. All this talk of production, news etc where their mentality is often 4:2:2 or it looks ‘black and white”!, I can only assume both these cameras are 4:2:0. I’m not sure how much this will hold these products back. I suppose in a studio you would use the analogue HD out which I assume, like the Z1 is 4:2:2 uncompressed, but in the field your stuck with 4:2:0.
    I’m curious now though, short of 4:2:2 and extra audio channels, how does ProHD differ from HDV in the HD100? I mean what does this ProHD logo really mean to the camera?
    Comment when you can 😉
    Glenn Johnson replied 21 years, 4 months ago 4 Members · 9 Replies
  • 9 Replies
  • Guy Barwood
    April 10, 2005 at 10:20 am
    I like the DC in connection outside the battery compartment, and the large 1394 connector (those little 4 pins are too fragile for my liking).
    Len says 5.5-88mm. Thats better than the other photo with 7mm-117mm shown.
    The more I look at this camera the more I love it, which is only going to frustrate me more and more because I just won’t have the money for it for some time.
  • Guy Barwood
    April 11, 2005 at 4:23 am
    Looking at the ‘other’ side more, I think they would have been better putting two RCA audio connectors where the 6pin 1394 port is, and putting the 1394 port horizontally under the 1394 switch (not needing the Line Out mini plug.
    See https://www.dilithium.com.au/temp/hd100_side2_custom.jgp to see exactly what I mean.
    Of course I can’t see whats under it, but I’m sure with the effort of the whole design process such a design could have been achieve.
  • Guy Barwood
    April 11, 2005 at 4:24 am
    opps, sorry that obviously should be https://www.dilithium.com.au/temp/hd100_side2_custom.jpg
  • Ken Freed jvc
    April 12, 2005 at 1:12 pm
    Yes Guy the camera does have live video output that is the highest level component seen by the camera. It is 4:2:2. So clearly it is before the encoder.
    After the encoder it is 4:2:0 MPEG-2 19Mbps GOP-6 1280x720p.
    The audio channels for this camera are 2. Once again there is this confusion between this and the larger 2/3″ CMOS camera which is likely to be 4 channels of higher data rate audio.
    I see people post about 50Mbps this or that. Actually this isn’t an applicable comment. For years we have shown 25Mbps D-theater tapes next to the Hollywood D5-HD masters and no one has aver been able to point to a part of an image or even motion and say “see that”.
    IMX is/was 50Mbps but that is I-frame bound so it isn’t effective MPEG2. I personally thought it not as good as DigiBeta. To use 50Mbps for a GOP MPEG2 would really be very much more than is needed. People confuse this with DV since DV compression is their only frame of reference. So they look at 25Mbps DV and say well then 50Mbps is much better. But MPEG doesn’t go like that. Different animal.
    So we will see in a week. Interestingly enough, the product people seem to be in a very happy mood. They think they have a special product.
    Ken Freed JVC
    1700 Valley Road
    Wayne, NJ 07470
    (800) 526-5308 x5419
    kfreed@jvc.com
  • Guy Barwood
    April 12, 2005 at 2:55 pm
    ah but Ken, it turned the 13th here 35min ago 😉
    I did a little non scientific test here, on the quality HDV can provide from a pretty much perfect source under perfect conditions (ie a high res still image downsampled).
    The results were very interesting.
    On one hand, it showed me that there is very little (none to my eye) difference between the visible colour resolution of 720p 4:2:0 and 720p uncompressed (4:2:2). This was very satisfying to see, and can only lead me to believe (unless my test is inherently flawed) that the difference we see in 4:2:0 to 4:2:2 cameras is much less about the colour resolution, and much more about the overall quality of the camera, lens and the size of the CCD block.
    On the other hand, it showed me that while HDV totally craps over DV, at the current bit rates there is a hell of a lot of compression going on. Maybe I just happened to pick an area that suffered more than most, but in the close ups of the neck and necklace with only a 3x magnification from a 1:1 on my LCD (and my TV is about 3x my LCD size), there is almost no skin detail left on the neck and clearly there are large artifacts around the necklace itself.
    It is a 5Mb total web page to load but please if you can have a look.
    https://www.dilithium.com.au/video/hdv_test
    Even if the Pinnacle encoder was not up to quality of the one in the HD100, the HD100 is going to have to deal with all that motion, which I would think might at least level the playing field with the test a bit, if not make the job much harder for the camera. It just has me thinking maybe the sweet spot for the data rate was a bit higher. Maybe I am over reacting though, after all I haven’t seen any real footage.
    I have printed A4’s of every photo of the HD100 released though 😉
  • Deleted User
    April 12, 2005 at 4:07 pm
    Hi Ken: It’s always great to see your posts here!
    Does the first US ship date for the GY-HD100 still look to be sometime in June ’05?
    If I’m not mistaken (and I may well be!), I believe this was mentioned here either by you or in a JVC press releases?
    In any event, are you able to confirm this timeframe, even in general terms?
    Thanks for any info you’re able to pass along about this and other new JVC products, especially for those of us who won’t be attending NAB this month.
    All the best,
    – Peter
    Just a friendly reminder to all: Please consider filling-in your COW user profile information so we have a better idea who you are, where you’re from, and so forth. It’s the friendly thing to do. Thanks!
  • Ken Freed jvc
    April 14, 2005 at 4:19 am
    There was an effort a couple years ago to decide we would be a company that would actually make our dates.
    I think we were late on the 500 five years ago and I think a real effort has been made to not do that. The 300 was on time. The 5000 was on time. The JY-HD10 was actually shipping to dealers the day we announced it. The latest projectors were in the month we said they would be.
    But having said that, June is hard. But the camera is rather far along. So it could be doable. It just might be June.
    It will be something to line a bunch of them up over the next 2 days and see what they do. Next week could be very busy.
    Ken Freed JVC
    1700 Valley Road
    Wayne, NJ 07470
    kfreed@jvc.com
  • Deleted User
    April 14, 2005 at 2:52 pm
    I’m looking forward to reading about all the new tools.
    Christmas in June, perhaps? 😉
    All the best,
    – Peter
  • Glenn Johnson
    April 14, 2005 at 7:15 pm
    Ken,
    What about Europe, Uk to be exact.
    Times for shipment? The various bits of press I have received have said June as well.
    Is this a world wide release then?
    thanks
    Glenn
