Activity Forums Zaxwerks More help please..
  • More help please..
    Posted by Henry on March 26, 2007 at 2:35 am
    I was kindly helped here.. https://forums.creativecow.net/readpost/41/857272?
    Just a further question.
    – I’ve done my edit (Text and Vide) in Comp A.
    – I’ve done my rectangle spinning in Comp B.
    – I’ve put Compa A in comp B, and have made comp A a lyer map.
    – Why is my text gray and fuzzy – instead of white text and clear?
    Thank you
    Henry replied 19 years, 5 months ago 2 Members · 2 Replies
  • Jon Okerstrom
    March 26, 2007 at 12:24 pm
    Hi henry,
    Be sure the precomp you’re using as a layermap has enough resolution if you’re zooming in close to the Invigorator object to which it’s applied… you may need to increase the resolution – but keep the aspect ratio the same. Also be sure that you have chosen “best quality” for the precomp.
    Jon
  • Henry
    March 27, 2007 at 5:03 am
    Thanks Jon. Will check this out. Thank you!
