Activity Forums Maxon Cinema 4D more ai fun – additonal questions
  • more ai fun – additonal questions
    Posted by Jon Lewis on December 14, 2005 at 2:21 am
    Along those same lines, I’m also needing a few helpful hints on working with illustrator files. I’ve got an AI 8 file imported, but have several layers of “ovals” that I would like to work with independently in 4D. What is the best way to do this. I’m adding an extuded NURB to the imported file, but the holes of the ovals in each layer remain filled in, and the individual layers don’t have any face to them don’t seem to be workable. The AI file has several paths (path 1, path 2… ) within it that are the layers from AI.
    Jon
    Jon Lewis replied 20 years, 9 months ago 2 Members · 2 Replies
  • Richard Powell
    December 14, 2005 at 9:16 am
    Function>Connect and Structure>Explode Segments are much the same as illustrator’s Make Compound Path and Release Compound Path. Sounds like you need to do some connecting.
    https://mograph.net
  • Jon Lewis
    December 14, 2005 at 4:10 pm
    Thanks will give that a try. I am new to C4D, any ideas on training classes is welcome…
