Activity Forums Apple Final Cut Pro Legacy mono files into fcp
  • mono files into fcp
    Posted by Seth Peterson on May 18, 2009 at 1:53 am
    Anything wrong with putting a mix down mono file into FCP instead of two split stereo files? I’ve gotten some edited dialogue and am confused why there are two of the same tracks to put into FCP? I’d like to make some changes to it but don’t want to spend time automating booth tracks
    John Fishback
    replied 17 years, 4 months ago
    2 Members · 1 Reply
  • John Fishback
    May 18, 2009 at 1:43 pm
    You can remove one of the tracks if you wish and pan the remaining one center. Or if you select both tracks and opt-L, then whatever you do to the first track will be mirrored on the other. Make sure to pan the tracks center to ensure a mono signal.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
