Monitoring without a deck
Hi, I’m in the process of setting up a new system using existing kit that has come from another studio.
I’ve got a G5 with a Decklink HD Pro 4:2:2 card (although it’s called a Decklink HD Pro (Single Link) in the system prefs if that makes any difference)
At things stand at the moment I don’t have a deck so I want to connect a broadcast monitor directly so I can use it in Final Cut Pro. I know that all this kit is compatible with each other as I’ve used in a different location. The only difference is I don’t have a deck this time. I assumed that this would be OK but it doesn’t seem to be happening.
I’ve got the output from the card going straight into the monitor and have tried various set ups but all I get a shash. It seems to be sending something but not a decent signal.
Is this even possible? Seems like it should be.
Chris
