Activity Forums Adobe Audition monitoring while recording….
  • monitoring while recording….
    Posted by Dana L. butler on May 15, 2008 at 3:39 am
    Can anyone tell me how to record live to a second track while listening to the first track without recording the first track to the second? (Audition 1.5) ….Electric piano line in to computer.
    Dana L. butler replied 18 years, 2 months ago 2 Members · 2 Replies
  • Mike Aurand
    June 2, 2008 at 1:58 am
    There may be 2 ways.
    If you have a mixer with at least 2 buses then you need to set it up so the computer output goes to 2 only and the input goes to 1 & 2. Then you monitor 2 and you’re good to go. (This is our setup. We have mixers with 8 sub buses. We assign 1&2 to the computer. We set every thing to 1&2 and MAIN {L&R} except the computer which we only rout to MAIN)
    You may be able to disable the internal mix on you sound card. On the recording mixer see if you can mute everything but your line in.
  • Dana L. butler
    June 2, 2008 at 3:47 pm
    Done and done. Thanks Mike. I don’t use a mixer and I tried every configuration known to man with my sound card and audition etc.. Then I rebooted with my keyboard already plugged in and presto…it works. I don’t know why it works now, but it do.
