Activity › Forums › AJA Video Systems › Monitoring to SD
  • Monitoring to SD
    Posted by Naveen Mallikarjuna on January 29, 2010 at 4:37 pm
    I posted this to an old thread, but realized a lot of people might not see it based on their viewing settings. So:
    I have an FCP project where the sequence is 1080p23.98. In the AJA control panel, when this is selected as my “Frame Buffer”, the Secondary (Converted) Format is greyed out. Does this mean I cannot monitor this in SD?
    I noticed that only certain formats allow a Secondary Format. So I guess this is true for all of them?
    Naveen Mallikarjuna replied 16 years, 8 months ago 2 Members · 2 Replies
  • Aaron Neitz
    January 29, 2010 at 5:25 pm
    Correct sir. You need to be working in the “sf” version: 1080sf/23.98
    that will downconvert to SD just fine.
  • Naveen Mallikarjuna
    January 29, 2010 at 10:14 pm
    OK, that’s what threw me off. It seems regardless that my sequence is 1080p24, I had to go to sf23.98. And you have to make sure all the FCP setting line up perfectly. A lot dominoes, but now it’s working.
    Naveen
    contact@naveenmedia.com
    http://www.naveenmedia.com
