Activity › Forums › Adobe Premiere Pro › Monitoring RED .r3d files on external monitor.
  • Monitoring RED .r3d files on external monitor.
    Posted by David Beard on February 27, 2013 at 7:35 pm
    Hey Cow Gang,
    I’m hoping you might be able to help. I’m having troubles with a new workstation, and figuring out my workflow. I primarily work with RED Footage. I would like to figure out a method of viewing my material on an external monitor. My Decklink Extreme 3d is falling short of this task, but I would hate to get rid of it, as I need external monitoring for Resolve. My old Kona card would take a 4k r3d, and displaying it out as 1080. This was brilliant!!! I’m so upset that I can’t do this with my Decklink. My next step would be to figure out how I can output out of a quardo 4000. Right now I have a GTX 570, but it is my understanding that only the quardro card has 10-bit output capabilities. I currently have two monitors for my desktop, so it sounds like if I did switch over to a quardo 4000, I would be limited to one monitor for desktop display, and one for 10-bit output out of premiere.
    Does anyone have any experience using a graphics card to output to a monitor that isn’t a capture card. I’m curious how this will work with the r3d footage. I read somewhere that someone was using this method, displaying 1080 from 4k. Any input on this would be great!
    Alex Gerulaitis replied 13 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Tero Ahlfors
    February 27, 2013 at 9:14 pm
    You can setup Premiere to playback through another monitor (if your monitor has DVI etc. in) in the playback settings so maybe that would work. Also you could work in a 1080 sequence and then render out in 4K or whatever you might need.
  • Tom Daigon
    February 27, 2013 at 11:31 pm
    Just as a point of comparison, Im running PrP CS6.03 and displaying on an external engineering monitor using the AJA Kona 3 with no issues whatsoever.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • David Beard
    February 27, 2013 at 11:48 pm
    I tried this with one of my apple monitors, and it worked likes charm. I’m curious what type of output this is. Is it 10-bit? I just need to get a dvi cable to run into my Flanders monitor. I also might consider a dvi to Sdi box, so I can loop through my Sdi on my Flanders to go out to my 55″ client monitor.
  • David Beard
    February 27, 2013 at 11:50 pm
    I had a kona 3 that did this beautifully, but I need a blackmagicdesign deck link for resolve.
  • Tom Daigon
    February 27, 2013 at 11:54 pm
    Yeah, that makes sense.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • David Beard
    February 28, 2013 at 12:53 am
    I’m curious if you’ve had issues at all with kona 3 output in after effects?
  • Tom Daigon
    February 28, 2013 at 12:58 am
    None that I recall.
    Tom Daigon
    HP Z820 Dual 2687
    64GB ram
  • Alex Gerulaitis
    March 5, 2013 at 1:07 am
    [David Beard] “Does anyone have any experience using a graphics card to output to a monitor that isn’t a capture card”
    Done it, it’s easy, although not on R3D files and not with a 10-bit monitor.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
