Activity › Forums › AJA Video Systems › monitoring hardware
monitoring hardware
Posted by Ajpme on October 20, 2005 at 11:19 pmCan I directly connect a pair of M-audio BX8 reference monitors to my K-Box?
Michael Lindsay replied 20 years, 10 months ago 7 Members · 13 Replies -
David Battistella
October 21, 2005 at 12:03 amSure,
But putting a mixer in between is probably a good idea. Unless you want to be turning your monitors up and down all the time.
David
Gary Adcock
October 21, 2005 at 1:35 am[David Battistella] “But putting a mixer in between is probably a good idea. Unless you want to be turning your monitors up and down all the time.”
Because of core audio
if you set your computer’s out audio to your Kona board, the keyboard commands to increase and decrease volume should work.But then, there is always the Audio mixer in FCP also.
Walter Biscardi
October 21, 2005 at 1:08 pm[AJPME] “Can I directly connect a pair of M-audio BX8 reference monitors to my K-Box?”
Yep, but I find it much easier to go through my Mackie 1202 so I can use the volume control on it. Also, I have multiple audio sources running through it (like the Cable TV of course!) so I can just bring up items as I need them.
Walter Biscardi, Jr.
https://www.biscardicreative.comNow editing “Good Eats” in HD for the Food Network
David Battistella
October 21, 2005 at 3:16 pmI’m with you Walter. I know it can be done without a mixer via the OS but I prefer the mixer. There always seems to be more things to listen to in an edit room than just the mac.
David
David Battistella
October 21, 2005 at 6:41 pmScot,
You have opened the door to a bunch of Big knob jokes here.
David
Ajpme
October 21, 2005 at 7:00 pmThis looks like the best option since I need the features it offers without the need for a full mixer. Can I connect 110ohm digital XLRs for all 8 channels into the Big Knob using 1/4″ adapters? Also, are 110Ohm cables required or will standard 75Ohm cables work?
From the Big Knob site: “Humorous product name ensures years of off-color studio humor”
Walter Biscardi
October 21, 2005 at 7:47 pm[David Battistella] “You have opened the door to a bunch of Big knob jokes here.”
Especially for fans of “Family Guy.” There’s a whole episode just waiting to be written here now.
Walter Biscardi
October 21, 2005 at 7:53 pm[David Battistella] “You have opened the door to a bunch of Big knob jokes here.”
Peter: Hey Lois! Check out Quagmire’s Big Knob.
Lois: Oh my, it’s so shiny and round.
Peter: So Quagmire, how many things can you monitor with the Big Knob?
Quagmire: Three Blondes and a Brunette. Diggity Diggity Do!
Cleveland: Oh Quagmire, that’s just naaaasty.
David Battistella
October 21, 2005 at 8:25 pmwell,
You shouldn’t really be considering anything but the larger cables with the big knob, as the big knob probably requires larger ohms, for sure.
The big knob likes the 110Ohm cables. let’s face it, if you’re gonna invest in the Big knob, get the most out of it with the best cables that can handle the load coming of the big knob.
d
