Activity Forums Sony Cameras Monitoring from EX1
  • Monitoring from EX1
    Posted by Greg Ball on May 5, 2012 at 9:05 pm
    I normally use the SDI output from the EX1 to monitor video. We’re shooting interviews this week, and the client wants to watch a monitor feed from a separate room. Can I use both the SDI output and the AV output out of the EX! simultaneously? Is that possible. Or do you have any other suggestions?
    Greg Ball replied 14 years, 3 months ago 3 Members · 3 Replies
  • Don Greening
    May 5, 2012 at 9:31 pm
    [Greg Ball] “Can I use both the SDI output and the AV output out of the EX! simultaneously? Is that possible. Or do you have any other suggestions?”
    On the original EX1 the component (RGB) and the SDI connections are both hot simultaneously. The A/V (composite) connection is active only by itself. If you have an external on-camera monitor, and it has a pass-through connection on the back then you can also send the video feed to the other room using that.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Dale West
    May 8, 2012 at 10:47 am
    Greg
    As Don says you might try using 2 monitors with at least 1 having SDI loop through but you might also look in the Markerteck catalogue for an SDI splitter. It has 1 in ans 2 outs, it’s passive and reasonably priced
    Dale West Video
    North Miami, FL
    305-588-2683
    dale@dalewestvideo.tv
  • Greg Ball
    May 8, 2012 at 2:36 pm
    Thanks Dale! Good to hear from you. Unfortunately my shoot is in 2 days, so I can’t purchase this in time.
